Hi,am working on the above machine and shows the above error. I have checked the laser system and looks properly ok.Initially the gear assembly of the main drive was broken and repaired,however after reassembling the unit this error crops up.Any assistance welcome,thanks
Sc302 on ricoh aficio 2018d
Tags: None
Re: Sc302 on ricoh aficio 2018d
Is it sc302 or SC320? SC302 is leaking main charge, SC320 is bad polygon mirror motorIBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications -
Is it 302 or 320? if it's 302 then you fingering the wrong Place,
SC 302 Charge roller current leak
A current leak signal for the charge roller is
Charge roller damaged
High voltage supply board defective ,,look for 2 terminals C & B from High voltage board to main drive(Gear BOX) bushings/Shafts,
SC320 bad polygon mirror motor.even if Drum is not rotating it will throw SC320 sometimes, which indicates you miss the trick in gear box,
Good luck,Comment
Paul@justmanuals.com
The actual error is sc302.when i disconnect the HVT board the machine gets ready,meaning either the charger roller could be defective or the connections.I will re-try and let you know.
Pse Llama that is kind of you i really need this manual.My e-mail is atellajames@yahoo.co.uk.Thanks in advance.Comment
I see that we're singing from the same hymn book; I emailed it this morning.
I also got home from work to find 10 new "likes," 9 of which were regarding the JustManuals thread. I'd hate to disappoint my public...!!!Comment
Hi guys, i revisited this machine and got the problem fixed.There was broken connection between the charger roller and HVT.Thanks to you all for your great contribution and especially Llama for the magic book.Comment
