How to upgrade Ricoh Plotbase 3.7.1 to 3.7.1sp4?
  • ecarats
    • 21
    How do I upgrade from Ricoh Plotbase 3.7.1 to 3.7.1sp4? My customer switched to autocad 2010, this requires the upgrade. I have the RSP file from Ricoh. I have downloaded 3.7.1sp4 from Ricoh. I have only had to install Plotbase twice. 1 full install and 1 upgrade. I need a refresher. If anyone would give me some directions I would be very grateful. Thank you.
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: How to upgrade Ricoh Plotbase 3.7.1 to 3.7.1sp4?
    Backup ALL your .RSP files! (put them in safe place as it's a real shit getting replacements now).
    Then it should just be a case of un-installing v3.7.1 restarting the PC, then installing v3.7.1 SP4.
    Then add .RSP file(s) back via the license manager.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Yes, that is exactly correct.
      Watch those RSP files and make 100 backups if you feel you need to. The chances are pretty much zero of getting them replaced!
      • ecarats
        • 21
        Thanks Guys,
        Getting the RSP file from Ricoh was no problem. I just called Ricoh tech support, they needed the serial from license manager and emailed the RSP to me. The uninstall and install sounds right to me. I think that's the part I wasn't sure about. I was thinking upgrade not clean install.
        Thanks again.
