2020D - Gap between hot and pressure roller??
  • OutlawTorn
    • Aug 2008
    • 189
    Hey all,
    Having this issue with a 2020D - there is a small gap on the left hand side of the fuser between the hot and pressure rollers.
    I have replaced both rollers and checked the springs on the pressure roller and they seem fine. Its only on one side as both rollers sit flush on the right hand side.
    Help, weird one. It's almost like the fusing unit casing has warped!
  • rthonpm
    • Aug 2007
    • 2853
    Re: 2020D - Gap between hot and pressure roller??
    Check the bushings for the pressure roller, they have a tendency to wear in strange ways. Also make sure that the aluminum lamp cover hasn't gotten bent as this will also give you a gap or a poorly aligned unit.
    • zed255
      How'd ya manage that?
      • 1024
      +1 for pressure roller bushing. Seen these wear out on one end only resulting in little or no pressure on one side of the fuser.
      • mikadonovan
        • May 2008
        • 2931
        Make sure the hot roller bearing on the rear has not slipped inward. The only thing that keeps that from happening is a plastic extrusion on the bottom of the case which breaks off easily. If it is broken, you can use a B079 bearing that has a collar on it to hold it in place. You can also use a long screw for the ground strap on the top of the stripper assembly to hold the bearing in place. They both work fine, as changing out the lower fuser casing is a pain.
        NEVER ASSUME ANYTHING
        • zed255
          • 1024
          I think you are thinking of the fuser found in the 1022 and onward. The 2020D is more akin to the 1018 style but with dual lamps and thermisters.
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
            • Masterchief
              • Apr 2011
              • 280
              Are the Bearings posistioned correctly, these can pop out leading to gaps.
              also make sure the lower frame aint broken
              sigpic
              • OutlawTorn
                • Aug 2008
                • 189
                Weirdly enough it was one of the plastic bushings that the pressure roller sits in that had melted!
                First time I have seen that one.
                • Masterchief
                  • Apr 2011
                  • 280
                  I had a feeling it was something to do with the frame, as when that piece is gone the bushing/bearings slip of causing this issue.
                  Im glad you have fixed it and learned from it. it will save you time in the future.
                  Masterchief
                  sigpic
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    Masterchief
                    Wasn't it the pressure roller bushings as mentioned above, or am I going mad?
                    Hit it.
                    • mikadonovan
                      • May 2008
                      • 2931
                      I would like to say "as a hatter", but you're right. First 2 replies methinks.
                      • mikadonovan
                        • May 2008
                        • 2931
                        Aye, I got my models confused. Not the first time and probably not the last.
