mpc 2500 s.c. 360
  • mrgene
    • 53
    mpc 2500 s.c. 360
    after changing out the black toner motor the day before we started getting sc 360 any clues.
  • pfinn10
    • Jun 2010
    • 46
    Re: mpc 2500 s.c. 360
    The error is Black TD sensor.
    Check toner supply (can be done in 5-804 output) make sure Toner is getting through.
    Try a new K PCU (dev unit included).
    Check to make sure you have the Toner motor installed properly, no crimped wires etc...
    Why did you have to change the Toner motor to begin with?
    • mrgene
      • 53
      the machine was not adding black toner. after we changed the motor it added toner and started to work.
      • COPIERMAN
        • Jun 2009
        • 559
        If blk dev unit doesn't fix problem could be I'd sensors are dirty or on transfer assy top roller bar is dull and needs to be buff or replaced or transfer belt is worn. I'd sensors shine through transfer belt on to bar and then back. I would try blk dev unit first.
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
