Ricoh MP4000B Please Wait
  • TecnocopyVI
    • 45
    Hi Guys,
    i have Ricoh MP4000b in the display sign please wait always , they haven't hard disk!
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Re: Ricoh MP4000B Please Wait
    Replace controller board brother. That's from my memory (running abotr 50% at the moment), I will check my notes tomorrow. Use the EEPROM's from the original too.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • Zeldaman
      • Mar 2011
      • 946
      Hi there!
      I agree! Normaly the HDD & the controller-board has to be changed.
      Greetings...
      • sandmanmac
        • 3979
        If the fuser is warm, it's probably the operation panel. If not, then BICU or Controller
        • Llama God
          • Mar 2009
          • 1353
          Does it come ready with the ADF unplugged?
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
            • sharpmind
              • Sep 2009
              • 478
              I agree,too!
              • TecnocopyVI
                • 45
                hi guys! i have change controller board but they sign sc819 what i make? thank you!
                • Masterchief
                  • Apr 2011
                  • 280
                  Hi
                  Did you also change the EEPROMS over, from the old to the new
                  sigpic
                  • DRichard
                    • May 2008
                    • 482
                    I'll pick up this old thread...
                    I had this same problem on an old MP 4000B with no add-on options. Replace the controller pwb with one from HyTec using the original NVRAMS. Fixed the problem but had an SC220 come up a couple of times. After resetting the machine and working on cleaning and some PM parts replacements it seemed to work OK for a bit. Now, after working through some sample pages the SC 220 has returned and isn't clearing. According to the service manual this code is indicating a Copy Data Security Unit mismatch or defect. This item is listed as optional and the copier doesn't have it installed. Might it be an artifact left on the rebuilt board I have gotten from HyTec? Any suggestions will be appreciated. Thank you in advance. Happy Holidays to all.
                    "Enjoy every sandwich."
                    -- Warren Zevon
                      the thread is about 6years old...
                      start a new thread
                      • DRichard
                        • May 2008
                        • 482
                        start a new thread
                        Sorry. I wasn't aware of the time limit...please forgive me.
                        -- Warren Zevon
                        • fshead
                          • 2368
                          i would call hytec and ask their ricoh guy,whose name i forget but he might be able to give you something to check...
                          I never worked on a mp400b but i think it is very old and might be time to sell a more current machine...
                          I myself would always try to keep old machines running but now i dont...
                          I need to make a living so if a machines gets 4-6 years use the customer needs to money up...If thet were dealing wth Ricoh direct that salesman is at the door after 3 years looking to upgrade machine...
                          • DRichard
                            • May 2008
                            • 482
                            We are in full agreement. However, this particular customer is a unique case and our options are limited. I have moved on from this machine and I may have found an acceptable alternative. Thanks for your constructive response.
                            -- Warren Zevon
                            • fshead
                              • 2368
                              Good luck..
                              As i see it even the best doctors lose patients,so i no longer try to keep every machine "alive for ever"...
                              In the end it allows me to get rid of old parts and supplies to make room for more current series....
                              I swapped out an old 20 yr old b/w and it took me saying that i couldnt find parts no more to do it...
