Ricoh 1232C No network printing
  • nmfaxman
    • 1702
    #16
    go to command propt.
    Type "ipconfig /all" space petween the g and/.
    Make sure the gateway and subnet mask match.
    Type in the IP address in a web browser and see if you get the web page.
    Check the port in the print driver.
    It should be set to LPR and the print queue to (lp) lowercase.
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      #17
      You may want to try configuring the port differently. If you go into the printer properties, select the PORT tab and click the CONFIGURE PORT button. You might try changing the port to LPR, changing the name to lp (LP) and enabling byte counting. I've seen it work in some networks.
      • biker_ted
        #18
        Ricoh still not printing
        Well, tried all of that. Hooked up a laptop with a crossover, pinged ok - no webpage though. It occured to me that why have an LPT port that works and an Network port that doesn't. Is this a permissions thing on the copier? I am beginning to think the lack of a Scanner/Printer kit is the reason - when I press the scanner button = double beep from the copier. However, when I press the printer button, I get paper tray option. Still scratching my head !!
        • iMind
          Vacuum Cleaning Expert
          • Mar 2008
          • 1116
          #19
          Originally posted by iMind
          Ted, see if this helps
          Suabe I think you right..... hehehe sorry Ted, if its true, theres nothing to laugh about.
          you´ll need: printer scanner and additional memory.
          • neergish
            • 177
            #20
            If you dont have a print/scanner kit a 'printserver' is a good option, plugs into the parallel of the MFD. We use DLink DP-301p+ D-Link DP-301P+ Fast Ethernet Print Server they work a treat.
            "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
            • iMind
              • Mar 2008
              • 1116
              #21
              If it works sounds like the best bye
              • biker_ted
                #22
                Ricoh Printing!!
                Yo success!! iMind - thanks for the pdf.....it identified the PCB's in the copier, so I could check Suabe's solution. The copier HAS the printer & scanner kit, but one of the PCB's was not "home". I reseated it AND IT WORKED!! Excellent!
                Thank you guys for all your help.
                • caini12345
                  #23
                  I am wandering if you set the ip address the same with another Pc,so you can ping it ,but you can't print on it,try to swithch off the machine and ping the ip again,it you can still ping it,then change it .
                  • ak01
                    • Jan 2008
                    • 14
                    #24
                    just happend to encounter this problem last week.i also got error message when printing but still i can ping the mfp ip adress.try reinstall new driver but the problem hold.then i create again the new port using the same ip and amazingly the pc can creat the ip bcoz its didnt recoqnize the same ip i create b4.i continue with the installation as usual and problem solve.hope dis will help.
                    • iMind
                      • Mar 2008
                      • 1116
                      #25
                      Try reading the post from the begining,
                      long solved
                      • ak01
                        • Jan 2008
                        • 14
                        #26
                        es ok im just sharing.symptoms is same.no need to write in bold.tq
                        • nmfaxman
                          • 1702
                          #27
                          Try to ping the machines Ip first. If it resonds type the IP into a web browser. The user id is admin the default password is password.
                          Check configuration.
                          Run CMD and do a ipconfig /all.
                          match ip address + 50, subnet same and gateway same as it came up in CMD.
                          Reload driver and set the port as machines IP, LPR port with the queue as lp, (as in laser printer lower case).
                          Make sure you set all the accessories as installed on the machine.
                          The picture on the driver should look like the machine.
                          Run a test page in the printer driver.
                          If you followed all this and it still doesn't work check the network cable or hub-router.
                          If you can print parallel there is nothing wrong with the copier other than a bad NIC.
                          • Scott_Lewis
                            • Mar 2007
                            • 519
                            #28
                            When only one PC is having a problem with connecting to a copier, one of the first things I do is delete the old IP port and create a new one on the PC.
                            • WWMAINT
                              #29
                              Check To See If You Add The Ip Address Correctly In The Print Driver Port. Print The Test Page From The Same Driver,.
