Nashuatec 1805 D copy with Printer controler 1018
  • samsogoye
    • Aug 2010
    • 30
    Dear Tech member,
    I need you help, I have been struggling to install the Printer on my laptop without success for one week now,
    my machine is Nashuatec 1805 d and printer control board is 1018 type, my laptop is running window 7 Pro and I use usb to parallel cable;
    the problem come when if finish to install printer and i use to choose usb virtual port but when I try to print test page it print continuously zero's and other unknown symbol.
    please help me
    Sam from Tanzania E.Africa
  • dickierock
    • 252
    Re: Nashuatec 1805 D copy with Printer controler 1018
    Which version are you using?,download latest here..
    http://www.ricoh-support.com/enduser...015_18en%2Ehtm
    • samsogoye
      • Aug 2010
      • 30
      Thanks letme try to install
      • samsogoye
        • Aug 2010
        • 30
        Problem Solved,
        Printing issue was caused by usb to parallel cable converter after using computer now its okey
