Ricoh SP3410SF firmware update problem
  • Doganays
    • May 2025
    [Error Code] Ricoh SP3410SF firmware update problem
    Ricoh SP3410SF firmware uptade problem
    We have recently updated to version v2.05 from v1.58. Watching the device display "initializing" writes. The device does not make any process. USB port and an Ethernet port can not access the printer. We can not get the service menu. clear 1-0-7 start not working.
    We want technical support. Please could you help.
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: Ricoh SP3410SF firmware update problem
    The older engine PCB has v1.xx firmware installed.
    (Not compatible with v2.xx engine firmware).
    The newer engine PCB has v2.xx firmware installed.
    (Not compatible with v1.xx engine firmware).
    You would have to replace the engine PCB if you flashed the wrong engine version by mistake as the machine will not initialize / startup.
    • Doganays
      Pcb card solution For me To Change no.
      Where I can buy Pcb card ?
