Slow PDF Printing MPC3001
  • CANCOUNTRY TECH
    • Aug 2008
    • 114
    Hi All,
    Have a customer with a mpc3001 at a construction site that prints building diagrams (roughly 8 pages at 5mb) it can take up to 30 minutes for the doc to print.Even trying to print the document with a cross over cable stalls.I have stopped/started the spooler.I have ordered a hdd and memory dimm question is is this a common thing with the 01 models.Printing the same document to a AF3260 at another location it prints fine.Firmware has also been updated.
    Any ideas much apperciated.
  • rthonpm
    • Aug 2007
    • 2860
    Re: Slow PDF Printing MPC3001
    Does either machine have PostScript? Generally that will remove a lot of slow PDF issues. Barring that, try using the PCL 5 driver and printing at black and white, 300x300 dpi. It's a work-around that doesn't quite solve the issue, but so long as there's no colour it will get the jobs out. Generally I create a custom setting for this in the driver and call it 'PDF' or something like that.
    • Cipher
      It's not easy being green
      • May 2006
      • 1309
      Make a note of all the network settings then try a NCS (SP5801-011) memory clear.
      Power off / on, then re-enter all the network settings again and give that PDF a test again.
      • nmfaxman
        • 1702
        Did you set the IP port to LPR? Queue name lp as in laser printerlower case.
        Sending to RAW uses the copier memory,LPR uses the copier HDD so spooling is faster.
        You can also select print as image in printer properties.
        • CANCOUNTRY TECH
          • Aug 2008
          • 114
          Hi All,
          Just an update in the printer config page i noticed ethernet speed was not set to auto.Once i set it to auto it prints like a dream.
          Thanks for all the input guys.
          • sandmanmac
            • 3990
            Originally posted by CANCOUNTRY TECH
            Hi All,
            I Was just about to make that suggestion. That setting has solved many a slow printing PDF for me too
