MP9000
  • francisco
    • Nov 2009
    • 168
    MP9000
    y have a strange problem whith a MP9000
    when copy sometimes very often logs sc 144 and sc 101
    i had replace MCU,lens unit ,scanner motor etc.
    ram clear, disconet HDD`s flash new firmware.
    if y work with adf i can see that few scanners the exp lamp turn off and machine reboot(log sc 101 and 144 and sometimes sc 955)
    if y put original in the glass, few scanners latter the exp lamp stay on in home position during seconds and machine reboots.
    in priter mode no problem.
    y hask some help for someone that had similar problem.
  • Masterchief
    • Apr 2011
    • 280
    Re: MP9000
    Is the ARDF unit sitting correctly and all connections fitted correctly?
    Was there any incident of a KNOCK during installation
    Can you post some examples of a copy after you have checed the lamps and rail...
    Also have you entered service mode and adjusted the scanner for auto
    sigpic
    • Voltage
      • Jul 2008
      • 282
      Re: MP9000
      [QUOTE=francisco;310611]y have a strange problem whith a MP9000
      y hask some help for someone that had similar problem.[/QUOTE
      SC 101 Exposure lamp error, Check or replace mirrors for damage
      SC 101 Exposure lamp error, Dirty white plate
      SC 101 Exposure lamp error, Exposure lamp defective
      SC 101 Exposure lamp error, Harness and connections
      SC 101 Exposure lamp error, Lamp Stabilizer defective
      SC 101 Exposure lamp error, SBU defective
      SC 101 Exposure lamp error, make sure white strip is on top of glass when placed on copier
      Maybe its helps
      • francisco
        • Nov 2009
        • 168
        Re: MP9000
        the copy are good until sc appear,i had see only one middle good and the rest black.
        i had disconect the ardf for testing and the problem is the same.
        the machine was disconect during one month and when turn on this problem begins.
        today i will try to change memory module.
        • francisco
          • Nov 2009
          • 168
          Re: MP9000
          [QUOTE=Voltage;310769]
          Maybe its helps
          i think i had change everything (exp lamp,lamp stab,sbu,mcu,harness)
          when the machine gets ready i can scan everithing i want to doc.server and then i can print.but if i try to make some copyies or scan to doc.server after print something i get this problem, i have to reboot and then i can save more in doc.server.
          srtangeeee isn't ittttt!!!!!!
          • Bantams
            • Jun 2012
            • 603
            Re: MP9000
            Replace the lamp stab.
            • francisco
              • Nov 2009
              • 168
              Re: MP9000
              i did.
              is the same
              • fbkhan3
                • May 2012
                • 421
                Re: MP9000
                Try new NVRAM,Format HDD restore the non defualt values in new NVRAM,flash a new and correct Firmware...when it sounds strange and weird deal with it strange way,
                good luck!
                • sharpmind
                  • Sep 2009
                  • 478
                  Re: MP9000
                  y have a strange problem whith a MP9000 when copy sometimes very often logs sc 144 and sc 101 i had replace MCU,lens unit ,scanner motor etc. ram clear, disconet HDD`s flash new firmware. if y work with adf i can see that few scanners the exp lamp turn off and machine reboot(log sc 101 and 144 and sometimes sc 955) if y put original in the glass, few scanners latter the exp lamp stay on in home position during seconds and machine reboots. in priter mode no problem. y hask some help for someone that had similar problem.
                  I would try to reseat all the connectors from the IPU to BICU. Before replacing major parts, make sure that all connectors are seated properly.Loose connections can cause strange problems which drive us crazy.
                  • francisco
                    • Nov 2009
                    • 168
                    Re: MP9000
                    today i put the controler unit(all unit) in other machine and no problem,i think i had tested all boards in other machine and no problem.
                    • katash
                      • May 2010
                      • 221
                      Re: MP9000
                      you need to order for the scanner harness one wire is inactive
                      • josueol1
                        Re: MP9000
                        board problem IPU
