mpc 4500 Random jams in trays
  • diego_akd2009
    • May 2011
    • 79
    [Jamming] mpc 4500 Random jams in trays
    Hi, I have a problem with a ricoh mpc4500, this paper jamming from all trays, the problem simulates a roller pad failure but already checked, when I print a single sheet out the following paper is 1 inch off the tray, then the next printing paper jams because this advance, the failure is random, and turning on the printer off and sometimes it works properly, replace the clutch in Trays , wipe the vertical transport sensor, replace / clean rollers and continuous failure, someone had this same problem? thanks
  • Masterchief
    • Apr 2011
    • 281
    Re: mpc 4500 Random jams in trays
    have you cleaned the friction pads in trays??
    and have you replace feed and sep rollers part id AF031049 x 2 and AF032049 x 2, to eliminate this problem
    as a rule of thumb, you must start from the bottom and work your way up...
    Also is the paper loaded correctly in trays as displayed on the operation panel
    Masterchief
    sigpic
    • diego_akd2009
      • May 2011
      • 79
      Thanks for your response! yes, I have changed the two pick-up rollers complete and the tray configuration is correct....
      • Masterchief
        • Apr 2011
        • 281
        Ok can you print off SMC Data Logs SC 5990-004 and reply with Jam location please
        sigpic
        • diego_akd2009
          • May 2011
          • 79
          yes, almost all jams occur in the vertical transport sensor 1 and 2 ....
          • TonerMunkeh
            Professional Moron
            • 3873
            RTB27 covers this. The sensor has been modified as apparently the detection circuit was not soldered correctly to the inside of the sensor. Part number is AW01 0128, NOT from lots FF08 - FK26. The lot number is on a sticker on the bottom of the sensor.
            Hit it.
            • diego_akd2009
              • May 2011
              • 79
              you would have to hand the newsletter?! thanks for the info!
