SP 5200 / Rings Fax
  • kalaris
    • 70
    SP 5200 / Rings Fax
    Hi
    Someone knows if you can adjust the number of rings on the Ricoh Sp 5200.
  • Horologydoc
    • Jun 2011
    • 61
    Re: SP 5200 / Rings Fax
    Should be able to change that in sp2103-007 parameter 6. You can't set it to 0. The value you enter is how many rings before an answer.
    • kalaris
      • 70
      try this setting even if it is not in the technical manual. thanks
