set scan folder on win 7
  • adween shaari
    Senior IT Technician
    • May 2012
    • 47
    [Misc] set scan folder on win 7
    hi there... need your help. actually i have install scan folder on ricoh mpc3500. for windows xp its works. but i have problem with windows 7. cannot use. the specific path cannot be found. after that cannot browse the network workgroup. need to reboot the machine after that can search workgroup again. can someone help me how to setup scan folder on win 7?
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: set scan folder on win 7
    first make sure the firmware is up to date. Second search the forums as threre are many posts for scanning to folder and win 7.
    Mystic Crystal Revelations
    • sandmanmac
      • 3979
      Agreed, I would just add, that scan to FTP is also an easy, non-firmware dependent solution (and seemingly a recurring theme of mine in this `fax`forum) if you have trouble locating the firmware
