jaming in the fusing unit
+ More Options
Posts
  • margic brian
    • Jul 2012
    • 97
    [Jamming] jaming in the fusing unit
    hi guys
    i have an mp 2000 that jams in the fusing unit when i copy anything with colour content and the copy gets wrapped around the hot roller what could be the problem.
    your assistance will be highly appreciated.
    thanks,
    margic brian.
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    Re: jaming in the fusing unit
    confused is it an mpc or mp. second whats the service life of the fuser you have in it and also is it oem toner?
    Incontinentia Buttocks
    • margic brian
      • Jul 2012
      • 97
      its actually an mp2000 and the fusing unit was just fixed last week no its not original
      • margic brian
        • Jul 2012
        • 97
        [QUOTE=margic brian;312729]its actually an mp2000 and the fusing unit was just fixed last week no its not original toner
        • banginbishop
          grumpy old git
          • Oct 2007
          • 894
          [QUOTE=margic brian;312730]
          so whats with the colour content bit? trying to understand as an mp2000 is b/w. what percentage is the copy i.e. 10% 80% coverage? you can adjust the lead edge to compensate for heavy coverage and non genuine toner is rubbish for these machines as well. destroys dev box unit, fuser jams and pcq. you can also adjust the picker finger metal plates but these cause premature wear ont the fuser roller
          • Bantams
            • Jun 2012
            • 603
            Are you using Glossy INKJET photo paper?
            • JustManuals
              • Jan 2006
              • 9838
              Paul@justmanuals.com
              • tcs04
                FORMER Techie
                • 1183
                increase the lead edge erase margin.
                replace the hot roller if contaminated by toner,
                use oem toner!
                • kyrenecopy
                  • Apr 2012
                  • 205
                  use oem toner!
                  DITO!!
                  Testing 1-2-3, testing, testing. Is this thing on?
                  • tcs04
                    FORMER Techie
                    • 1183
                    use oem toner!
                    Sorry To banginbishop!
                    just realised I repeated most of what he said!... RTFP!!
                    • banginbishop
                      grumpy old git
                      • Oct 2007
                      • 894
                      ha ha no probs, there was a bulletin on the old af model and there was a couple of sp adjustments on them for the same problem. if you still persist on crap toner adjust the silver plates on the stripper fingers but it does wear the fuser quicker than normal.
                      • Masterchief
                        • Apr 2011
                        • 280
                        Might also be worth changing the PR and putting some grease on the bearing. Since your using crap toner is the any buid up of toner on the fusing entrance plate or exit guide, and what condition are all the pf rollers in and reg roller.
                        sigpic
                        • josueol1
                          • lorenzo
                            • Dec 2008
                            • 20
                            use oem toner!
                            right.. also check the paper separation claw (stripper).. good luck!
                            • margic brian
                              • Jul 2012
                              • 97
                              thanks everyone for the info i can see consistance so will change the bushings may be hot roller and get oem toner
                              thanks again
