Aficio 1027 - "Please Wait Sign On"
  • andrewdecruz
    • Jul 2009
    • 74
    Dear friends,
    Has any one come across this problem on a Aficio 1027 before? After switching on, the machine panel display just shows "Please Wait" and does not turn to "Ready" . It's a basic machine without print/scan/fax connectivity. I have not replace any parts yet but i am suspecting it's the power supply unit?? Thanks in advance
  • Masterchief
    • Apr 2011
    • 280
    Re: Aficio 1027 - "Please Wait Sign On"
    Or it could be something to do with the Fusing unit. Have you checked the FU, also does this machine have a HDD its been that long since i worked on one i have forgot
    sigpic
    • Athlontini
      • Jun 2012
      • 269
      If it's a basic machine then it wouldn't have a hard drive.
      Firmware update?
      • josueol1
        Originally posted by andrewdecruz
        Dear friends,
        the cause of the problem must be the thermistor from melting. Make sure the temperature in SP 1106 roll up this merger.
        Another cause and firmware upgrade.
        • Masterchief
          • Apr 2011
          • 280
          Ok im awake lol, i have had 3 types of problems with this machine grounded at please wait.
          The transfer sep roller on the door was shot, as soon as i replaced it all was well
          The fusing thermostat had blown and needed bouncing of the wall to start, i replaced it later
          and the PCU had damaged the spring at the rear from removing and installing (Hard)
          Try these 3 i bet you will be sorted
          sigpic
          • Eric1968
            • 2458
            If the machine has the Printer/Scanner Unit installed then 99,999% chance that the HDD is broken. You can try to format the HDD in a PC, or replace it.
            • tomcatt
              • Jul 2010
              • 92
              If you do not need print scan function just unplug the hard drive.the machine will work as a copier although duplexing may not work
              • JustManuals
                • Jan 2006
                • 9838
                Paul@justmanuals.com
                • vargue
                  • Oct 2011
                  • 404
                  hdd problem
                  • CableGuy
                    Impulse Drive Engineer
                    • Oct 2008
                    • 417
                    The quickest way is to unplug HDD and fire it up...If it still hangs up, try any of the above.
                    • mikadonovan
                      • May 2008
                      • 2931
                      Dude. Did you know your playing your bass backwards?
                      NEVER ASSUME ANYTHING
                      • margic brian
                        • Jul 2012
                        • 97
                        will go for hdd and anything like thermistor in fusing unit
                        • sana
                          • Aug 2012
                          • 3
                          Dear friends,
                          is it giving any error code after long time sc 672? this hard dick problem format the Hdd.
                          • Eric1968
                            • 2458
                            ...hard dick problem?
                            Sorry, it has been a busy week...
