Savin 8025e fax confirmation report
  • mungooz
    • Dec 2007
    • 34
    Does anyone know how to turn off the fax confirmation report on the 8025e model? My customer only wants a report to print out if there is a fax transmission error and not for every fax transmission. Appreciate any help on this. Thanks.
  • rthonpm
    • Aug 2007
    • 2854
    It's pretty much the same as most Ricoh MFP's:
    Under Fax Settings in User Tools, go to the User Parameters in the Key Op Tools tab and change switch 03, change bits 0 and 5 from '1' to '0'. Bit 0 disables the confirm page for memory TX and bit 5 kills the confirm for immediate TX.
    • FRIDGEMAGNET
      • Aug 2007
      • 377
      Try this - all taken from the fax user manual
      User parameters SW3 bit 0 to 7
