RICOH MPC2050 with FAX issue
  • ricmartinho
    • 142
  • Jomama46
    • 2900
    Re: RICOH MPC2050 with FAX issue
    ECM decoding error. If its only one customer, it is probably a problem with their machine. Turn off ECM on your end.
    sigpic
    A+; Network +; PDI+
    • ricmartinho
      • 142
      Cheers!
      Our customer already told the sender that the problem should be on the sender side but they didn't care!
      Willl disable ECM and report back.
