Re: Odd MP 2550 Fax Issue
Decreasing the initial TX and RX speed seems to help some issues, and my customers can't tell the difference.
I turned off ECM and the problem continues.
JeffLeave a comment:
You get repeat pages when the fax believes it had too many errors.Either tell the offending customers to have their line cleaned up or you can turn off ECM.Leave a comment:
Just replaced a Aficio 1035 that had print net scan and fax. Everything worked as it should including the fax on the 1035.
So I deliver the MP 2550 and a couple of days later the customer says that 2 or 3 of their customers incoming faxes
are received funny. They constantly get 3 page 1's from each of these customers. All other in coming faxes seem fine.
So 3 first pages...not 4 or 2 always 3, but only from the same 2 or 3 customers.
And the 1035 I pulled out always received faxes fine.
Ideas? ...customer is getting tired of it and frankly as much as I like a good mystery it's getting old and I'd like to figure it out.
Thanks for taking the time to read this!
Jeff D.
St. Louis
