Ricoh 2852 Dead
  • bobthecopierman
    • Mar 2010
    • 53
    Ricoh 2852 Dead
    Have a fairly new 2852, less than 20k, which is dead except for the blue light near the power
    button on the control panel.
    Outlet power is okay.
    Initial checks point to the power supply but I just wanted to check the forum to see if there were any
    simple solutions I might be missing.
  • Masterchief
    • Apr 2011
    • 280
    Re: Ricoh 2852 Dead
    Just before you replace the board have you tried to brighten up the screen, I have been to 4 calls were a prankster has dimmed the screen leading me to think the board gone?
    sigpic
    • bobthecopierman
      • Mar 2010
      • 53
      Re: Ricoh 2852 Dead
      Thanks for the tip Chief. I did check that. When turning on the main power switch there is
      no warm up rotation or anything else except for the blue light by the power switch.
      • greyfox
        • May 2010
        • 20
        Re: Ricoh 2852 Dead
        Mate have you tried checking the Controller Board?
        • bobthecopierman
          • Mar 2010
          • 53
          Re: Ricoh 2852 Dead
          Checked voltages going into controller and the only reading I could get was on a 5v line which is
          why I suspect the PS.
          • duct tape
            • Jun 2009
            • 87
            Re: Ricoh 2852 Dead
            If the machine is connected to a network check the web image monitor for any codes or messages. That has helped me in that sort of situation.
            • Boonboon
              Re: Ricoh 2852 Dead
              Replace the IPU board
              • skynetto
                • Sep 2012
                • 257
                Re: Ricoh 2852 Dead
                Had a similar situation on a MPC2000, check the IOB-BCU flat cable connection. Make sure it is fixed on the controller.
                • sharpmind
                  • Sep 2009
                  • 478
                  Re: Ricoh 2852 Dead
                  I encountered the same problem in this model with only 60k copies. I replaced the controller board and the machine worked fine.
                  • dpoutz
                    • May 2011
                    • 78
                    Re: Ricoh 2852 Dead
                    I know on the newer machines you must unlug the machine from the wall for 15 minutes or so for the psu to reset
                    • neergish
                      • 177
                      Re: Ricoh 2852 Dead
                      Looks like a known board issue with this model. We recieved instructions from MR Ricoh to change the controller and or IPU Boards of any the MP 2352/2852/3352SP next service call (Ive only one in the field)
                      Serial numbers affected
                      Contoller
                      MP 2352SP - W661H10001 to W662H200283
                      MP 2852SP - W671H10001 to W672H240042
                      MP 3352SP - W681H10001 to W682H200003
                      IPU
                      MP 2352SP - W661HA00014 to W661HC00226
                      MP 2852SP - W671HA0001 to W671HC00052
                      MP 3352SP - W681HA00001 to W681HC00194
                      "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
                      • bobthecopierman
                        • Mar 2010
                        • 53
                        Re: Ricoh 2852 Dead
                        Thanks for all the tips. Turned out that it was a bad controller bd.
                        • Polarbear
                          • Feb 2012
                          • 1070
                          Re: Ricoh 2852 Dead
                          @Neergish
                          Are you getting re-imbursed for the boards? Or does Ricoh expect you to pay for them? We are also experiencing this sort of failures on machines that are (in one instance) a week old!
                          Press the GREEN button!!
                          • neergish
                            • 177
                            Re: Ricoh 2852 Dead
                            Originally posted by Polarbear
                            @Neergish
                            We were sent one of each board free to cover the one possibly affected machine we have in the field, although I think the machine has since been moved out of our area, so now they will probably sit in my part shelves gathering dust.
                            According to the rework noticed RRN 0004 issued by Australian national tech support
                            Please replace the controller and/or IPU board during next visit or on failure.
                            Ricoh Japan has agreed to provide replacement boards free of charge for the affected machines listed above.
                            Due to insufficient stock Ricoh Australia will provide dealers and branches with an initial stock to cover a percentage of the machines in the field (MIF). We expect to deliver the replacement parts within 2 or 3 shipments to cover all affected MIF.
                            In addition Ricoh Japan has offered a nominal payment to cover labour cost.
                            So ricoh should cover you, call your tech support and badger them.
                            • Polarbear
                              • Feb 2012
                              • 1070
                              Re: Ricoh 2852 Dead
                              Thanks for the feedback!
