Ricoh 2022 sc 320
  • Rick
    • Mar 2007
    • 277
    Ricoh 2022 sc 320
    The laser unit is gone on this unit and I dont have another one in inventory . Is it possible to use one from a 2018 complete or can I take the polygonal motor out and put it into the 2022 as a temporary fix ?
  • kyrenecopy
    • Apr 2012
    • 205
    Re: Ricoh 2022 sc 320
    The machines laser assy are totally different, they are not interchangable. The laser and the polygon mirror motor are also different. sorry
    Testing 1-2-3, testing, testing. Is this thing on?
    • Rick
      • Mar 2007
      • 277
      Thanks anyway I guess if the customer needs dependability they should invest in a newer unit .
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • nmfaxman
          • 1702
          It is possible to take the rotor/ mirror off the base to clean it and just lightly coat the shaft with oil.
          It will whine a bit, but it will run.
          Otherwise replace the motor.
          These are workhorse machines if you just keep them clean.
          • Lea@ABM
            • Aug 2007
            • 47
            I'm not 100% sure but I'm guessing the nearest you find that will fit is a 220/270 or 1022/1027 as they work at the same speed.
            • Phil the copy guy
              • Sep 2009
              • 36
              I have swaped just the motor with success ! But you can buy a new motor for 29.00
