Aficio 1075 - How to reset password
  • super222dooper
    I have a Ricoh Aficio 1075, which has been moved to my building from another building and it is locked out.
    In order for me to put it on the network I need to be able to access the System Settings. This is password protected.
    Does anybody know how to by-pass this or FULLY reset the MFD.
    Super D
  • Steve Perks
    • Mar 2008
    • 32
    To change an Administrator password, you need to log in as a Supervisor.
    The default is usually username=supervisor password=supervisor
    This will enable you to 'supervise' the administrator account(s) including resetting of the administrator password.
    Team Leader/Technical Specialist: CMYK Digital Solutions Ltd
    • Ricoh-ono
      • 339
      Actually, you reset the Key Operator Code with SP 7-810 on the 1075.
      Do what you can, with what you have, where you are. ~Theodore Roosevelt
      • SF Tech
        • Sep 2009
        • 14
        Lanier LD160/Aficio 2060 Login
        Hello,
        I got used Lanier LD160, and can not Login, I have tried with SP, It does not have the SP7810 or 5828-74, tried the Supervisor, Blank, Admin
        Any Idea?
        Thank You
