Hi guys
If have a machine thats controller board we cannibalized. I ordered a new one and received it today. I inserted the previous boards memory, HHD and NVram and printer/scanner SD card. I boots up but there is no printer option. The scanner option is available aswell as the fax. I might be imagining it but when I go into system settings, it seems to take longer as usual . I did check in the sp mode if the nic was enabled.
Any ideas...
Any ideas...
