Ricoh 3260c PCU Stand needed?
  • patterson70
    • May 2010
    • 599
    Does anyone know if this is a must to have when rebuilding the pcus? It is missing from the bottom of the machine.
  • Polo-022
    • Sep 2007
    • 486
    Re: Ricoh 3260c PCU Stand needed?
    Tool makes the difference!
    This tool protects the drum, you can order it for your convenience and for those unexpectable scratches...
    • patterson70
      • May 2010
      • 599
      Thanks for the info, does anyone have one for sale in this forum?
      • TonerMunkeh
        Professional Moron
        • 3865
        The part number is B132 2391. You should be able to order one directly from Ricoh.
        Hit it.
        • patterson70
          • May 2010
          • 599
          I think they cost around $50, anyone have one for maybe $20 they don't need? Please Private Message me if so.
          • Herrmann
            • Jan 2006
            • 792
            you are not in need to spend much $ for plastic rubbish, a soft blanket will do the trick
            If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
            • nmfaxman
              • 1702
              Wrap a piece of paper around it, and lay it down with the fold down, or roll it up in a soft clean rag.
              The idea is to keep it out of direct light.
              • patterson70
                • May 2010
                • 599
                Thank you all for your ideas, will use a soft towel or similar. I appreciate the help!
