CL 7200 CQ ISSUES
  • mikadonovan
    • May 2008
    • 2931
    CL 7200 CQ ISSUES
    Picture 1 is what I was facing upon arrival, along with sc374 codes.
    Picture 2 is after I replaced the black development unit.
    Picture 3 is after I replaced the black pcu, and as you can see, something is still awry.
    I swapped the transfer unit with a known good one, no change.
    I vacuumed out the K toner supply tube
    I made sure the toner pump was working (forced K toner supply, and it overtoned)
    Has anyone seen this issue on this printer? Looking at pic 3 it kinda looks like a K dev bias issue, but I'm not sure. Could use some assistance on this one. Thanks
    NEVER ASSUME ANYTHING
  • BLADE
    former propeller tester
    • 478
    Re: CL 7200 CQ ISSUES
    developer drive clutch
    • TonerMunkeh
      Professional Moron
      • 3865
      That'd be my guess too, it can be about the only thing you haven't changed so far.
      Hit it.
      • rthonpm
        • Aug 2007
        • 2847
        Developer clutch. There was a bulletin released for the LD 335c family on this issue: the clutch stays on too long and then feeds out too much developer, depleting prematurely.
        • Bantams
          • Jun 2012
          • 603
          Black dev clutch 100% but you will need to replace the blk dev unit at the same time as the dev as probably all gone by now.
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
            • Imprestik
              • Aug 2012
              • 296
              Yes I have had this issue many times before and it is a black Dev clutch. Since your at the back of the machine you might as well do all clutches as well
              • mikadonovan
                • May 2008
                • 2931
                The developer clutch did the job. Thanks Guys. Thank you too, Paul, but I already have the manual
                • Sharp2
                  • Oct 2012
                  • 7
                  Don't forget the black toner attraction pump. It has a clutch sealed in it (dumbest idea ever) that will cause insufficient toner to developer unit under load. This pump as it starts to fail gives the diagonal banding as well. As you are back there for the DV clutches (do them all you will be the better for it) check the pump too.
                  • mikadonovan
                    • May 2008
                    • 2931
                    The exact same problem is back, and all the developer has been lost from the unit. Could it be I installed a faulty dev clutch, or could something else be causing this problem?
                    • Bantams
                      • Jun 2012
                      • 603
                      did you replace the dev unit when replacing the clutch?
                      • mikadonovan
                        • May 2008
                        • 2931
                        Yes, it was a brand new unit that got the dev sucked out of it.
