I have a probelm with this machine that I can't seem to solve.
I have replaced the toner clutch, developer unit and the PCU. I have also cleaned the toner pump and still have yet to find a solution.
My next thought was to clean the laser optics....
The customer has been using generic toner from Precision Roller and the toner has worked well in the past...
(The dots at the top of the page in the pdf attachment are from the scanner as there are no "dots" on the actual print...just a gray area).
Your thoughts are appreciated.
The Tenor Man
The Tenor Man
