Hi.I have an mpc 2050 that ,when switched on the machine doesn't do anything. The led above the soft power button on the Rhs of the operation panel is the only thing that is lit.The pwoer supply has been replaced recently.Any ideas would be welcome.
ricoh mpc 2050 no power
Re: ricoh mpc 2050 no power
Paul@justmanuals.com -
I had this problem once on a MPC2000. One the small green light was on and nothing more. No heat, nothing on screen ecc. Found out it was the flat cable that was damaged by the previous tech that has opened the machine. The one that connects the iob with the bcu. Maybe yours is just out of its place. It takes just a few screews away to find out, worth to try.Comment
I guess you have a similar problem as mine I experienced few months ago with MPC2551.
Ended up replacing BICU + polygon mirror motor at the same time and it resolved the issue.
P.S. before I got to that resolution I replaced touch panel, power supply for a touch panel, checked all fuses etc. nothing helped. Good luck!Comment
i have the same on mpc 4500 but jest led fore 2 sec and break downComment
Hi. Had the same problem and on my machine it was the BICU. Good luck!!Comment
samuele
i had this problem in mpc 2500 and was the poligonal motor .But can be other motor, try to disconnect some motor like poligonal or also the laser unit . In mpc 2800 was laser unit but not poligonal motor. In mp 8001 was power supply failed..Comment
Laser cable separated there is Nothing try to disconnect pol +fuse+lct nothing i think that is the power supllyComment
