MPC 4500 Fuser clips
    Hi
    The fuser on this machine slides out on rails and has two plastic clips that stop the fuser being lifted out of the machine.
    Anyone have the part number?
  • mikadonovan
    • May 2008
    • 2931
    Re: MPC 4500 Fuser clips
    A2222724- external circlip: Mm8
    NEVER ASSUME ANYTHING
    • Herrmann
      • Jan 2006
      • 792
      in my opinion, you can leave them alone, no need to attach/replace them
      If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
      • collme
        Ricoh tech
        • 221
        I have a few hundred of these machines in 1 account and all these clips have not been refitted once removed.
        • SGT_Snacks-64
          • Oct 2007
          • 157
          Agreed with above, if anything, I believe it's a safety feature to stop users removing the Fusing Unit completely (Much like the later models having the metal brackets)....... and dropping it when it's scolding hot.
          I'd say advisable, but not the end of the world if they're not there. It's not gonna cause jams etc
          Intel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
          Asus P5E-VM HDMI
          4GB (2x 2GB) Corsair XMS Xpert II RAM
          ATi Radeon 4870 512MB GFX Card
          2x 74GB WD Raptor Sata HDD (RAID 0)
          500GB Seagate Barracuda Sata II HDD
          500GB Hitachi Sata II HDD
          600W500att OCZ PSU
          -TOTAL HDD SPACE 1148GB-
