Glsr type 1515 photocondutor unit
  • FixingMagic
    • Sep 2012
    • 12
    I have a GLSR TYPE 1515 PHOTO CONDUCTOR UNIT (411844) I installed it into my customers machine. The copies that come out are now dark gray. Does anyone have more information on what the problem could be?
  • ucinn
    • Jun 2009
    • 383
    Re: Glsr type 1515 photocondutor unit
    I've had that twice and both times it was just a bad PCU out of the box... replaced and sent back warranty.
    • FixingMagic
      • Sep 2012
      • 12
      Is this a common problem for most techs?
      • sandmanmac
        • 3983
        I wouldn't say 'common'.
        I'd say 'Shit happens'.
        • ucinn
          • Jun 2009
          • 383
          These PCU's have been out for quite a while and I've got a few hundred of the units that use these PCU's, so two out of thousands I wouldn't say is a problem.. I would say it goes under the "shit happens" category mentioned above.
          • FixingMagic
            • Sep 2012
            • 12
            What is causing the drum unit to print excessive toner onto the paper? Is the drum being overcharged?
            • Venom
              Technical/IT Support
              • Nov 2009
              • 765
              Generally too dark means poor main charge contact
              IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
              • FixingMagic
                • Sep 2012
                • 12
                My customer is quite angry at me .-.
                Would there be a way I could troubleshoot to find a better solution?
                • sandmanmac
                  • 3983
                  It's a defective assy. You bought it that way. Replace it, and return for warranty.
                  Problem solved.
                  If you can't claim warranty because of where/ how you acquired it, that's not your customer's problem.
                  I'd be angry too
