how do i assign an ip address
  • margic brian
    • Jul 2012
    • 97
    hi i would like to assign an ip address to a ricoh 171 or basically configure it on the network client does not have network admin
  • sandmanmac
    • 3963
    Re: how do i assign an ip address
    RTFM
    • Jomama46
      • 2900
      User Tools> system settings>interface>network>IP4 address>specify> (enter address + #) enter subnet mask + #. OK your way out, print a config sheet to verify. You can also enter a Gateway if necessary under "network"
      sigpic
      A+; Network +; PDI+
      • TonerMunkeh
        Professional Moron
        • 3865
        This is a joke, right?
        Hit it.
        • margic brian
          • Jul 2012
          • 97
          even to me it ssemed like a joke until i did enter an ip address,subnet mask into the copier and when you ping it on the pc it does not appear neither when the ip is put into the webbrowser-i hope this aint no joke now
          • margic brian
            • Jul 2012
            • 97
            thanks i will try adding the # tag . but for what reason please clarify that could be my problem cause i didnt do it that way thats why i failed
            • margic brian
              • Jul 2012
              • 97
              Originally posted by sandmanmac
              thanks for the link will use it
              • Eric1968
                • 2458
                If you put in the IP-adres/Subnet Mask with #, press OK to program.
                • margic brian
                  • Jul 2012
                  • 97
                  it may sound silly but if i may ask without # tag it wont work? if no why cause i did all that without #tag
                  • Jomama46
                    • 2900
                    No, # just means the symbol on the screen which means "Enter" You still have to OK the whole screen to program.
                    sigpic
                    A+; Network +; PDI+
                    • margic brian
                      • Jul 2012
                      • 97
                      i get the logic behind and than
                      ks eveyone for the info
