MPC2050 SC144
  • GeorgeBest
    • Jul 2009
    • 526
    MPC2050 SC144
    Hello,
    Got this error code on a MPC2050. (SC144)
    Customer said it came spontaneous.
    he can't copy & scan, but the printer function is working allright. !
    Never seen this on a C2050.
    Is it as the manual says the flatcable or BICU board ?
    Thanks in advance . .
  • JustManuals
    • Jan 2006
    • 9838
    Re: MPC2050 SC144
    Paul@justmanuals.com
    • Eric1968
      • 2458
      Re: MPC2050 SC144
      First check all connections between the SBU-board and the BICU-board. Don't know if it's the BICU or the SBU. I would start with the cheapest parts.
      • 3bok3bok68
        Senior MFP Technician
        • Nov 2008
        • 56
        Re: MPC2050 SC144
        try to print test pattern, if you can print the test pattern, replace SBU assy.
        • GeorgeBest
          • Jul 2009
          • 526
          Re: MPC2050 SC144
          Noticed that the scanner is not coming on home position and no copylamp action.Means that the BICU board is out ?Do you have the part nm of this BICU board ?Thanks in advance
          • Eric1968
            • 2458
            Re: MPC2050 SC144
            D039 5102 BCU Assy
            • GeorgeBest
              • Jul 2009
              • 526
              Re: MPC2050 SC144
              Thnx !
              D039 5102 BCU Assy
