Any idea why TD initializing on this machine will fail. I am guessing the TD sensor is faulty and i am going to order one tomorrow. Just want to know if someone thinks it can be something else.
Is the dev unit seated properly? I've had various issues with this sort of thing. Doesn't always throw up an error, but sometimes an extremely light copy produced. Unbolt all the gear holding the drum and dev unit in and reseat them and try again.
There was a issue with the firmware when they first came out causing failure when initializing the dev check and update the firmware before replacing any parts never had a TD sensor fail on one of these yet.
