MP6500 Lan Fax
  • MitchD
    • Oct 2012
    • 164
    [Misc] MP6500 Lan Fax
    I have a MP6500 that the customer wanted to start using LANfax or PC faxing. I installed the driver and pointed it to the static IP of the copier and tested. Nothing. The PC releases the "job" but it doesnt activate the fax option on the copier and send the fax out. The fax works fine as a "walk up" function, just not from the PC. All firmware is current and the OS on PC is WIN7 64bit.
    I have installed this driver more times than I can remember at other locations with no problems. This one has me stumped.
    "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
  • sandmanmac
    • 3979
    Re: MP6500 Lan Fax
    I've read that there's a bulletin about a problem with the print/scan SD card when LanFax doesn't function, so the card needs to be replaced. Although I don't have access to the bulletin for the specifics
    • MitchD
      • Oct 2012
      • 164
      Re: MP6500 Lan Fax
      WOW! Good call. I must have looked right over that one. I just found it and my machine falls in that s/n range so I will go out there later and replace the print/scanner SD card.
      Thanks again
