Ricoh CL4000DN HDD Hard Disk Drive Questions
  • jsulliva
    • Sep 2010
    • 64
    [Error Code] Ricoh CL4000DN HDD Hard Disk Drive Questions
    Ricoh CL4000DN HDD Hard Disk Drive.
    Manual indicates HDD is Type 4000 and holds 40GB. Companies are still asking $200-$300 for these, which should get 100x the capacity (3-4 Terabytes) now.
    40 GB drive should be about $10 at my local Goodwill if I know what to buy.
    Is there a generic that will work instead?
    Or do you know OEM MFG and part number of the drives (I don't think Ricoh is in the HDD business)?
    Thanks,
    John
  • sandmanmac
    • 3983
    This threads a little old but I thought I'd weigh in just in case you haven't solved the issue. I only deal with the copier side of things but all of those Ricoh boxes use standard Ide or Sata drives (depending on the age). I can't imagine the printer division being any different. It's easy enough to tell by removing it and having a look
    • jsulliva
      • Sep 2010
      • 64
      Re: Ricoh CL4000DN HDD Hard Disk Drive Questions
      Thanks for the information. I was hoping to find an exact brand and model number as it increases the likelihood it will work. But I will look at it and perhaps try an experiment. Probably IDE and I have some old ones somewhere.
      Thank you,
      John
      • sandmanmac
        • 3983
        Thank you,
        John
        Model and brands don't make a difference when it comes to these. There's simply nothing special about them - except it must be at least the minimum size that's in the machine.(Ie: 40Gb), but the maximum is not an issue. I've replaced 40Gb with up to 250Gb without issue.
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          Ditto what sandmanmac said, the knock from ricoh on the bigger drives is the power required (current) for the new drives can cause board failure. Never had it happen. the other part is the mounting hard ware.
          Mystic Crystal Revelations
          • jsulliva
            • Sep 2010
            • 64
            Thank you both - that's the kind of practical advice I can put to use.
            I will have to look in my box of old disk drives for something that will fit.
            Thanks again.
