The HDD, Controller and BICU have all been replaced, all firmware up to date but this error still appears intermittently after a reset message on the display. Managed to move the fault to another device by swapping the HV board but the error has since appeared back on the original device after replacing the HV with a new one.... any clue would be appreciated.. Cheers
SC687 MP4000
Tags: None
Re: SC687 MP4000
Memory address (PER) command error
The BICU does not receive a memory address command from the controller
for the prescribed time after the paper has reached the registration sensor.
Harness Disconnection at BICU
Controller board loose or broken
Defective BICU
Defective Controller Board -
Re: SC687 MP4000
Cheers Barratec, I think I have a NVRAM back at the ranch, I will give it a go. Might also try a backup and NVRAM clear to see if that changes anything... Will keep you posted.Comment
Re: SC687 MP4000
Paul@justmanuals.comComment
