2035 sc 322 laser
  • gursel1907
    • Mar 2009
    • 2
    2035 sc 322 laser
    2035 sc 322 laser failure was scrubbed dpi settings support ...
  • T0ner M0nkey
    • Aug 2012
    • 4
    Re: 2035 sc 322 laser
    Hi There, not sure of your actual issue here but if you have replaced the polygon motor and having issues, you will have to reset and initialise the beam pitch. If you are still getting 322 after replacing the polygon motor or LD, you would be wise to check/replace the dorr switches, especially the ones above the fuser unit.
    • kannuki2
      • Feb 2012
      • 398
      It's normally not necessarily needed to perform the dpi pitch adjustment on the small black and white box. Just pop the laser board and done out the door.
      • sandmanmac
        • 3981
        I disagree completely. On this series? Why would you skip it anyway? it takes 30 seconds
        • vargue
          • Oct 2011
          • 404
          why yo keep your machine dirty every p.m clean it very well.look to seals .if it fret replace it. your machine will be fine.and yo will never see this code after that.
