mpc 2050 jams at 24
  • ash_572
    • 523
    mpc 2050 jams at 24
    i am getting a jam code of 24= inverter sensor.
    i removed the stapler that sits in the internal to narrow it down.
    single sides are ok but when making duplex copies it jams at the exit section (the upper rollers) where it would enter to go through the stapler.
    ive checked the actuators on the gate on the duplex side and they seem fine. springs are still on.
    machine has done 5000 copies until it started jamming for no reason.
    seems like the gates are not diverting the paper into the duplex section.
    what can it be? any help would be appreciated.
  • JustManuals
    • Jan 2006
    • 9838
    Re: mpc 2050 jams at 24
    Paul@justmanuals.com
    • pocket aces
      Ricoh Technician
      • Nov 2008
      • 72
      I get that all the time change the inverter sensor GW010007
      • totoro
        • 568
        Jam Codes 019, 020, 021, 024, 027
        Teflon Sheet on Duplex Exit Guide Plate peels off
        Install New Duplex Exit Guide Plate - D0394985
        Totoro
        • teebee1234
          • 1670
          X2, the sensors in that section are notorious for failure. If you haven't done it yet, do an input check with the sensor blocked and unblocked and confirm if there is a change in state.
          • M0scb
            • Oct 2012
            • 32
            I have had problems with the junction gate solenoid not operating correctly. Even with new springs fitted it does not quite open fully in duplex mode. Replacing the junction gate had no effect. Fitting a stronger spring on the lower section of the solenoid cured the problem.
            • ash_572
              • 523
              it was the inverter sensor. replaced and sorted. thanks for the help everyone
              • teebee1234
                • 1670
                Thanks for the followup, it adds to our collective knowledge base.
                • CableGuy
                  Impulse Drive Engineer
                  • 417
                  Had this for the first time last week. Replacing the sensor did the trick
                  • drew007
                    • May 2018
                    • 21
                    I have this on an mpc5503.
                    simplex ok but the paper stops at the inverter rollers. the 024 code just means the paper hasn't reached the sensor, which it hasn't, because the inverter rollers havn't turned.
                    I've tried turning motors in output check. duplex and exit motors work fine but the inverter motor doesn't work at all.
                    I've changed the inverter motor for a new one. I've changed the inverter/exit unit for one out of an old machine. (customer has one in the basement they've forgot about).
                    I'm ready to change the IOB board next.
                      everyone else fixed their problem with the inverter sensor... maybe the one you swapped was bad?
                      • drew007
                        • May 2018
                        • 21
                        I can see the sensor change state on input check. I think that I may have a different problem.
                        Still looking at iob board.
                        • Mark Bbb
                          • Jun 2012
                          • 1662
                          1. Did you clean the paper path and all rollers (very) well?
                          2. especially the rollers at the junction gate (above the F.Unit) get dirty quick, they must be really clean.
                          3. have you test the duplex function with a new - good brand and dry - paper?
                          4. I have never replaced 1 sensor on this model, so it would very surprise me that this is the issue. Of course, sensors needs to be cleaned too.
                          5. We install a tray heater, and no matter what some technicians says, it really helps!
                          6. Good luck
                          • drew007
                            • May 2018
                            • 21
                            the rollers aren't turning. so the paper isn't hitting the sensor.
                            can't activate the rollers in output check.
                            can see sensor on input check.
                            • Mark Bbb
                              • Jun 2012
                              • 1662
                              I have replaced inverter sensor with no luck.
                              I notice that, without the covers, it's working better than with all covers attached.
                              I think replacing the whole exit/inverter unit will fix the problem.
