HELP???!!!
  • red flower
    • 28
    HELP???!!!
    Hello , Please help i want to know how can i cancel priniting network status page at power up for aficio copier??
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    what is the model?, JESUS, one minute ago and you off line. faster than lucky luke, hehe
    login via browser IP address then log in as admin. default is sysadm password is password then uncheck box first item of the page.
    see you soon in paradise...................... I only taught you because we have to save some trees, more the better.
    • red flower
      • 28
      model is aficio 350 or 551
      • iMind
        • Mar 2008
        • 1116
        login via browser like the above post, tell us what happend
        • red flower
          • 28
          how can i do that
          • Ollie1981
            Toner Monkey
            • Mar 2008
            • 417
            Those machines are both pre-GW architecture machines, they have pretty basic print controllers similar to what you find in the smaller printer range (AP410N) and soforth, so there's no web browser.
            I should imagine there's an option in the printer dipswitch settings to turn this feature off. But unless you're a tech I doubt you'll be able to do this.
            • iMind
              • Mar 2008
              • 1116
              No web browser. hehehehe, are you from Mars
              • Jomama46
                • 2900
                I dont think you can turn this page off in this early model.
                sigpic
                A+; Network +; PDI+
                • iMind
                  • Mar 2008
                  • 1116
                  Al, are you also from mars
                  • Jomama46
                    • 2900
                    Yes, yes I am
                    sigpic
                    A+; Network +; PDI+
                    • iMind
                      • Mar 2008
                      • 1116
                      Yes, yes I am
                      Look at this:
                      • Jomama46
                        • 2900
                        Paul you are right!
                        sigpic
                        A+; Network +; PDI+
                        • iMind
                          • Mar 2008
                          • 1116
                          Imind, I believe you, now show me the one for the AF551 and/or 350 that he was talking about
                          Al, the ( grafic interface) or Gw if we can call it so, is the same, simple but helpfull. anybody please HELP me....
                          Imind at you service, hehehe
                          User operation manual: NAD 30/40
                          (Machine code: A230, A231, and A232)
                          Aficio 340/345/350/355/450/455
                          Chapter 3
                          Using the Management Access
                          Program or a Standard Web Browser
                          MAP has the following requirements:
                          . The Microsoft TCP/IP protocol stack, the Microsoft IPX protocol stack, or Novell
                          NetWare 32-bit IPX protocol stack must be installed on this PC.
                          . A web browser must be installed on this PC. Both Netscape Navigator and Microsoft
                          Internet Explorer (3.02 or later) are supported.
                          The Management Access Program (MAP) uses a Windows-based HTML viewer
                          program linked with a proprietary bi-directional IPX/IP channel program to allow access
                          to the Network Interface Board's HTML-based monitoring and maintenance capabilities.
                          An IP Web Browser also provides access to this capability directly. Either program
                          allows you to:
                          . Configure your network protocols for the Network Interface Board.
                          . Reset the Network Interface Board remotely to either clear an error condition, or
                          return the print server to its factory default settings.
                          . Troubleshoot problems in the Network Interface Board.
                          . Enable or disable the status sheet printout.
                          . Access a context-sensitive help menu that fully explains how to use each
                          Management Access Program feature.
                          . Access the online help that explains how to use the many features of this program.
                          Note: Some functions provided with the Management Access Program or the
                          Web Browser require a password. The factory default password is "sysadm".
                          Web IP Browser
                          Once you have assigned an IP address to your Network Interface Board, you may use an
                          IP browser, such as Netscape, to access the HTTP Server and the HTML code allowing
                          Network Interface Board monitoring and maintenance. To access the HTTP Server
                          screens from your browser, do the following:
                          1. Open up your browser by clicking on its icon.
                          2. For the URL, type in the IP address of the Network Interface Board (ex.
                          http://192.9.200.200). The HTTP Server screens should appear.
                          If you have problems, check to make sure you are using the correct IP address.
                          • Jomama46
                            • 2900
                            It pains me to say it Paul, but I was (gulp) WRONG!
                            But there is no web interface for the 551
                            sigpic
                            A+; Network +; PDI+
                            • iMind
                              • Mar 2008
                              • 1116
                              It pains me to say it Paul, but you are (gulp) WRONG!
                              There is no web interface for the 551 or 350.
                              Look at the previous post.
