Ricoh Aficio SPC311s SC542 error - HELP !!
  • savard
    • Aug 2025
    [Error Code] Ricoh Aficio SPC311s SC542 error - HELP !!
    The power went off the the other day than came back on. Today I went to print some brochures for a customer and all I get is this error message. I read here there is some type reset, does anyone know how I go about that...help is hard to find here in the hills of Tennessee
  • JustManuals
    • Jan 2006
    • 9838
    Re: Ricoh Aficio SPC311s SC542 error - HELP !!
    Paul@justmanuals.com
    • Herostrat
      • Oct 2012
      • 220
      That SC means machines thermistor readings are eather,wrong due to pileing of toner on them,or Fuser doesn't reach designated tempreature in time.
      I sugest u clean thermistors...gently,and try entering service mode and type in 5801002# turn off then on.
      It helps sometimes ...sometimes u need new thrmistors.
      Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
      • savard
        Thanks will give it a try
        • collme
          Ricoh tech
          • 221
          There is a service bulitin for this RM040001d which shows they have brought out a firmware upgrade for the engine to version 2.4. this upgrade prevents the error if the ac voltage fluctuates between 10-20% which yours did.
          • kannuki2
            • Feb 2012
            • 398
            you need to download smart organize monitor from Home | Ricoh Global and it is available for windows Vista/XP only.
