Ricoh af-2045 - sc322 and 326
  • Michael
    • Jun 2025
    I changed de flat cable that connects that bicu board with the laser unit and the sc 322 and sc 326 codes still appear.
  • DocF
    Old Retired IKON Drudge
    • 41
    Remove the laser unit. Clean all the toner and dust out of it. Clean the synch sensor very carefully. If codes continue replace the LD unit. They tend to fail on these machines more often than on 1035 account excess dusting.
    Doc
    • Jomama46
      • 2900
      Another possibility for the same reason (dusting) is the upper right cover switches, as the power for the LD runs thru them. Great place for a switch, right above the toner.
      sigpic
      A+; Network +; PDI+
      • Ollie1981
        Toner Monkey
        • Mar 2008
        • 418
        Hehe,
        Great place for a laser unit on these, right below the toner hopper on a notoriously dirty machine.
        First of all check that the laser slit glass is still there, I've seen a couple of machines where the slit glass has been missing completely and it's been throwing up laser SCs.
        Then do what the other folks say, careful clean of the LD unit, I have had a couple of occasions where the lens directly in front of the laser diode has been coated with a layer of toner, cleaning this has cleared the fault.
        A couple of occasions where a clean of the sync board has sorted the fault.
        But anyway, 9 times out of 10 this has come down to toner contamination either of the door switches or the LD unit itself.
        • aalex_bom
          • Jan 2008
          • 214
          af1035-1045
          i have 8 machines Af1035-1045 - all the show sc 326-322.
          i can not repair bacause i have not LD,
          • scully
            • Mar 2006
            • 46
            Have you tried resetting the Laser Pitch Beam Adjustments in 2-109 because you should maybe carry these out !
            John
            Uk
            • Jomama46
              • 2900
              How in the world did you manage that?
              sigpic
              A+; Network +; PDI+
              • aalex_bom
                • Jan 2008
                • 214
                i tried on more way but it stills appear.
                it stay in store.
                • Jomama46
                  • 2900
                  8 machines doing the same thing. You need to find something else in common.
                  All point to a laser sync error. Usually caused by dirt on the laser sync boards. But as has been said, after cleaning you should reset the Laser Pitch Beam Adjustments in 2-109. The number is on the birth certificate.
                  sigpic
                  A+; Network +; PDI+
                  • vaclav borc
                    • Jan 2008
                    • 75
                    I had code 322 - on ricoh machines - you must take apart polygon mirror
                    motor,cleane round bar with alcohol . Now you must little eperiment with
                    oil. a) use very little of oil, only microfilm - if variant a doesnt work
                    - b) use more oil .
                    i repaired ever laser unit this way - both HP LJ printers
                    • Jomama46
                      • 2900
                      You're not going to fix Ricoh LD motors like this.
                      I think yours laser sync boards have an oil coating on them. (maybe an oil coating with a little toner mud on top)
                      sigpic
                      A+; Network +; PDI+
                      • npwright
                        service manager
                        • 12
                        check the front door switches 1 mounted top right corner the other bottom left corner the ones to check are the ones with three wires on them as they are both in the laser circuit.
                        also perform dpi beam adjustments and make sure all cables are connected properly and are not trapped .
                        • ak01
                          • Jan 2008
                          • 14
                          yup.try change all door font/right swithches especially those 3 right above the fusing unit.usually it can solved the problem
                          • mgarretson
                            I've also seen the three door switches cause the same thing. The three switches on the right side of the machine.
                            • oswaldo160
                              • Oct 2008
                              • 69
                              Ricoh 2045 sc 322
                              Hi.
                              What is the best solution with this problem?
                              because I probe the others but the solution is temporaly.
                              Thanks.
