duplex problem (1 orig. -> 2sides ) , the double sided are reversed in the paper !?
  • hema999
    • Jul 2025
    [Error Code] duplex problem (1 orig. -> 2sides ) , the double sided are reversed in the paper !?
    hello guys ,
    I have Aficio 161mp spf machine ,
    -It was working fine in the duplex mode (1 orig. -> 2sides )
    I put the papers in the same orientation & it produce the papers in a right orientation
    -suddenly without any changes in the copy settingsI could recall :
    when using the ADF ,the outcome is reversed 180 degree on the other side of the paper !!
    the orientation setting is -as default- don't specify .
    I know if I choose always specify I could get it to work fine , but through a lot of steps every time
    I want it to work automatically as it was before .
    thanks in advance
  • JustManuals
    • Jan 2006
    • 9838
    Re: duplex problem (1 orig. -> 2sides ) , the double sided are reversed in the paper
    Paul@justmanuals.com
    • sandmanmac
      • 3981
      That is a bit of a strange one. I don't know what might cause it, other than possibly a 'glitch' in the system software.
      My only suggestion would be to try a soft reset by holding * and # simultaneously for about 12 seconds, until You hear the machine click and/or beep. Release them, and the machine will reboot.
      Don't worry, none of your settings will be affected.
      • hema999
        Thanks sandmanmac
        I did what you told me & it printed a diagnose report with no errors !
        And the problem still exists
        Can I update the whole firmware by connecting it to my pc ?
        ( If it's easy to do & may help fixing the problem , what do you think ? )
        • sandmanmac
          • 3981
          Firmware update may do the trick, but it's not that simple, or readily available to end users, so you will probably have to call a depot in your area if you want to proceed
          • hema999
            I asked the retail supplier I bought the machine from ,
            he told me that this is the normal mode ! & all copiers he have does the same thing !
            & he didn't believe me when I told him that it was copying the 2 sides in the correct orientation .
            I asked him about the firmware , he told me that I would give him the machine BIOS so that he would install a new one on it .
            but there is no use from it since that all the firmwares he have does the same thing !
            After some asking , I found out that there's settings for that issue but for other models :
            123User Tools/Counter
            Copier/Document Server Features
            General Features
            Next Page 2/4
            A- Duplex Mode Prority= 1 Sided to 1 Sided
            B- Copy Oriention in Duplex Mode= Top to Top
            C- Original Orientation in Duplex Mode= Top to Top
            I don't have these settings on my machine , but for sure there will be other settings = these , right ?
