MPC 7501, banding in all colors (CMYK).
  • Staffan
    • Aug 2025
    Hello.
    I have a problem with a Ricoh MP C7501.
    The machine has about 200,000 in color and 50,000 in the black.
    I get banding in all four colors.
    I go into the SP2-109-2 Select Pattern and choose 100% Coverage.
    Then I set these values:
    SP2-109-05 Density: K to 15
    SP2-109-06 Density: M
    to 0
    SP2-109-07 Density: C
    to 0
    SP2-109-08 Density: Y
    to 0
    Enters the Copy Mode, choose Color, choose A3PCU / Devunit:
    • Developer.
    • Drum.
    • Both CL-Blade
    • CL-Brush.
    • Coatningbar.
    • I have cleaned Dr. Blade.
    I have changed these parts in the Image Transfer Unit:
    • All four Image Transfer Rollers.
    • Paper Transfer Roller in the ITB Unit.
    • The cables from the Transfer Rollers down to the Power Pack.
    • The actual Powerpack.
    • Bearings on both sides (and therefore cable from Paper Transfer Roller to PowerPack) of Paper Transfer Roller in the ITB Unit.
    • Both CL-Blade.
    • Both CL-Brush.
    • Coatingbar.
    I have changed these parts in the Paper Transfer Unit.
    • Paper Transfer Roller.
    • Coating Bar.
    • Both CL-Blade.
    • Both CL-Brush
    Now I'm out of ideas, what can cause this.
    Maby the paper starts to go unstable when it comes over to feed between Paper Trasnfer Unit and Fuser-unit.
    But is not 48 mm between Paper Transfer Unit and the feed after that, it is too short.
    I'm more into that the Power suply Board can not provide enough power to the BIAS-rollers in the developer unit and / or Paper transfer Rolers.
    All modifications are made, it's newest software.
    Please, is there any ideas!
  • zames77
    Tweak it till it breaks!
    • 121
    Re: MPC 7501, banding in all colors (CMYK).
    We'd really have to see an image to give you any decent help, otherwise we're just guessing at what might be the cause. Can you upload the image?
    • stu
      Hi can you post a sample pic? Having similar issue, banding in mainsscan direction, looking likes the dev units in my case,
      • Eric1968
        • 2458
        Don't think it's a Power Supply issue. There are some issues regarding image quality and toner scattering. Engine and System firmware should be the latest versions. I have a few bulletins, but unfortunately they're in Dutch.
        • TonerMunkeh
          Professional Moron
          • 3865
          Looking at the list of parts you've fitted to the PCU's you haven't mentioned that you have replaced the charge roller assemblies on the colour PCU's. Are you only getting banding on CMY or black too? If it's just CMY it could be the charge cleaning rollers have broken down.
          Hit it.
