Ricoh MP C2500
  • iscott
    • Mar 2010
    • 344
    Ricoh MP C2500
    In Service mode / Original Jam History / What sensor does 004 Indicate?
  • Eric1968
    • 2458
    Re: Ricoh MP C2500
    Skew Correction Sensor, if my memory serves me right. But you can also print SP5-990-4 to see what sensor is registering the jam.
    • JustManuals
      • Jan 2006
      • 9838
      Re: Ricoh MP C2500
      Paul@justmanuals.com
      • SargeNZ
        • May 2012
        • 263
        Re: Ricoh MP C2500
        What is also handy when troubleshooting sensors is to go into periphs > ADF > INPUT CHECK and make each sensor changes from 00000000 to 00000001 when you place your finger over them. Also gives visual confirmation of the sensors location.
        • Max
          • Oct 2011
          • 557
          Re: Ricoh MP C2500
          If it is Df you have problem with the sensor might be ok but the patch for the sensor will be covered in paper dust so checking the sensor with a finger will not help.Clean all patches 1st.
          • kannuki2
            • Feb 2012
            • 398
            Re: Ricoh MP C2500
            Most of the time, that jam code is caused by the DF feed clutch. Open the Df rear cover and run about 20 pages duplex and apply some pressure on the clutch's shaft. If it stops, then you know you need some good cleaning or a new one.
