Screen black
  • javaman7471
    Service manager/Tech
    • Jan 2012
    • 16
    Screen black
    I am working on a Ricoh MPC 2000 (actually Lanier LD420C) same thing I have green power light on red alert light red light on printer button but my display on op-panel is dark no light at all, I have tried a new operation panel with no luck, any hints on what to try next I was told to try polygon mirror motor because it may be indicating an SC 220 code which could cause a dark screen but I cant get into Web Monitor to verify any SC codes although it does beep like it has an SC code when turned on. Any help is appreciated. Thx all.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Screen black
    Have you tried shining a torch onto the screen? The SC code may still be visible; the screen won't have the backlight on.
    • johnyb
      • Feb 2011
      • 167
      Re: Screen black
      Have a look at SC 202 in the FSM, ant the related RTB.
      • Imprestik
        • Aug 2012
        • 297
        Re: Screen black
        Your power supply is cactus, replace the power supply....
        • skynetto
          • Sep 2012
          • 257
          Re: Screen black
          Black screen on MPC2000 occurs even when Fuse NR4 is blown on the PSU.
          • Zeldaman
            • Mar 2011
            • 946
            • JustManuals
              • Jan 2006
              • 9838
              Re: Screen black
              Paul@justmanuals.com
              • turbojetboy
                • Aug 2009
                • 279
                Re: Screen black
                Correct, you must repl polygon motor assy and BICU AT THE SAME TIME BEFORE SWITCHING BACK ON, or else you will blow the BICU again. This is now a common sight accross the range from 2500 through to 5000.
