Ricoh Mp 1350 in 'Please Wait' Status
  • Meyvyn
    • Sep 2025
    Good Day Everyone, i have a Ricoh Aficio Mp 1350 machine which is always in 'Please Wait' state. I have tried interchanging IOB, Power Supply Boards, BCU, and the entire controller unit from a working machine but none worked for me. Help will be highly appreciated. Thanks in advance guys.
  • collme
    Ricoh tech
    • 221
    Re: Ricoh Mp 1350 in 'Please Wait' Status
    Had the same on an MP2550 recently and i changed all the usual boards and hard drive. ended up being the display control pcb. can you take control panel from a working machine to try?
    • Meyvyn
      Thanks for the reply, I'll try doing that....
      • tcs04
        FORMER Techie
        • 1183
        There's a post in the Ricoh UK tech forum relating to MP1100 / Pro 907 type machines displaying "Please wait" at various times. Advice was to adjust the spacing of the plug and socket at the rear of the fuser to ensure good contact.
        Symptom:
        Cause:
        Action:
        You can place a spacer between the fuser connector and the frame on the fuser unit. The plastic e-clip off some of the clutches is very good for this, part no 0805 0088. However if you still experience problems you may have to replace the connectors.
        • PinevskiS
          • Jul 2009
          • 283
          Turn off machine and disconnect HDD .After turn on machine ,if machine start up turn off connect only one HDD turn on machine and after that
          Format only one HDD.
          Turn off machine connect second HDD turn on machine if start up format both HDD together.
          • df3036
            • 109
            Just swap the hdd cables and turn on. Worked twice for me on different MP 9000's
            Kittens give Morbo gas.
            A+, Network+, Server+, PDI+
            • Meyvyn
              Thanks for all the great replies, I finally got rid rid of this 'please wait' problem, but now the machine is displaying sc 124...described in the service manual as 'Encoder Signal Error' another thing is in the machines sc history an sc 305 is logged latest, Charge Corona Wire Cleaner Error 1...
              • reyphox
                • Jun 2012
                • 7
                What fixed your 'Please Wait' problem on your MP 1350??
                • kubusiek77
                  This one worked for me! Thanx.
                  • chuck cota
                    I had the same issue on a 1350 about a year ago. Make sure fuser and duplex connectors are clean and there is no paper or debris stuck in them. Also, make sure that the duplex is firmly closed.
                    If problem persists try to enter service mode and check to see if fuser is warming up.
                    When I had the problem it was caused by a small piece of paper stuck in the duplex connector.
                    Good luck
