hard disk serial number
  • patrick045
    • Sep 2010
    • 38
    is it possible to print out the serial number of the hard disk ?
    for example for ricoh mpc4500
    kind regards
    patrick
  • sandmanmac
    • 3980
    Re: hard disk serial number
    kind regards
    patrick
    Not to my knowledge, but it is possible to take 5 minutes to pull out the controller and read it off the drive(s). There are 2 of them.
    My question would be "why"?
    • Polarbear
      • Feb 2012
      • 1070
      I have searched the service manual and checked a full smc print for the MPC4500 and cannot seem to find it anywhere.
      +1 with removing the controller and doing a physical check.
      Press the GREEN button!!
      • CableGuy
        Impulse Drive Engineer
        • 417
        I would image it's printed on the tin? Interested to know why
        And how is beautiful Cape Town today?
        • Polarbear
          • Feb 2012
          • 1070
          CableGuy
          Had wonderful weather in CT yesterday (Wednesday) but today it is overcast
          • LittleTurtle
            Well there are many methods for that yes one could be removing the HDD or back cover of your lap or if its a PC remove the casing and there are ways you can do it using your os itself go to your device manger and then you can see your hardware details if not you can use simple applciations such as HDD ID Utility 1.0 you can find it here Download HDD ID Utility 1.0 Free - It will show your HDD serial number and other key information. - Softpedia
            • sandmanmac
              • 3980
              Oh man....
              Dude. It's installed in a RICOH COPIER! You're in the 'copier forum'. Pay attention.
              • CableGuy
                • 417
                Hi Sandmanmac. I think he is trying to drum up business, not much info in his profile and links to all sorts of things. Not necessarily copier related?
                • margic brian
                  • Jul 2012
                  • 97
                  Originally posted by sandmanmac
                  Oh man....
                  someone just lost their bearings is that the apple logo ."just thinkingout loudly"
                  • Sweden_GBG
                    • Nov 2012
                    • 74
                    I still wondet too WHY? what to do with sn on the hdd? Or is it the copier sn you wanted?
                    • TonerMunkeh
                      Professional Moron
                      • 3865
                      Unless it's a warranty claim thing and the serial number is required for that maybe?
                      Hit it.
                      • rthonpm
                        • Aug 2007
                        • 2849
                        I was thinking either that or maybe a high security customer who wants verification for audit purposes that a hard drive in a specific machine hasn't been removed or altered in someway.
                        • patrick045
                          • Sep 2010
                          • 38
                          indeed it is a high security customer
                          i was wondering if i could make a print out with both machine type and serial number as well as the serial number of the hard disk .
                          thx for the replies
                          • rthonpm
                            • Aug 2007
                            • 2849
                            The machine itself won't give you the option to print the hard drive serial number since there's nothing in the NetBSD of the copier that holds that information and the drive controller doesn't broadcast it.
                            Your best option is to visit any machine you need the serial for and pull out the controller and have a customer witness record the serial number. Since they're the ones wanting the information, they'll need to take at least the ownership of investing the same amount of time as you to get the serial numbers.
                            Good luck!
