Ricoh MP 4500 says door open
  • Rick
    • Mar 2007
    • 277
    I was just performing maintenance installing new drum unit and when I closed the doors the message stayed on the display to close door as shown but there is no
    open door displayed . I opened and closed each door and watched as the display showed me that the doors were actually opening and closing . But still it displays the message to close door as shown but no door is open . What did I do to create this problem ?
  • Eric1968
    • 2458
    Re: Ricoh MP 4500 says door open
    Check the door switches?
    • Rick
      • Mar 2007
      • 277
      I did check them and they seem to be working . The display says open door but doesnt indicate which door .
      • nmfaxman
        • 1702
        Blown 24v fuse on the power supply will give a constant door indicator.
        • vargue
          • Oct 2011
          • 404
          clean front door switches very well. if it's not work out replace switches 24v dc
          • collme
            Ricoh tech
            • 221
            I second that
            • JustManuals
              • Jan 2006
              • 9838
              Paul@justmanuals.com
              • nmfaxman
                • 1702
                • hafn
                  • Aug 2008
                  • 4
                  I have the same problem, can you help?
                  • sandmanmac
                    • 3981
                    So you're saying that none of the above solutions has worked for you?
                    (I doubt it)
                    • Rick
                      • Mar 2007
                      • 277
                      make sure the door magnets are in place properly
                      • Rick
                        • Mar 2007
                        • 277
                        make sure the door is closing all the way . The magnets can come loose and stop the door from closing completely . Thats what was wrong with my unit .
                        • hafn
                          • Aug 2008
                          • 4
                          ok
                          The problem occurs once in a while. The display says door open but does indicate which door.
                            • 37487
                            (I doubt it)
                            Me thinks he just replied to the thread without reading the thread. Appears to be a newby.
                            • Oze
                              Ricoh Fanboy
                              • Jul 2008
                              • 1663
                              The door switches that sit above fuser(stoopid idea) get baked with toner and need to be replaced...used to happen all the damned time with 3500/4500 back in the day....replace them and all will be well.
