mp 3500- sc352
  • tullio
    • Feb 2012
    • 268
    mp 3500- sc352
    error sc352. every 1000-1500 prints. drum again, same problem.
  • Eric1968
    • 2458
    Re: mp 3500- sc352
    This error is about a dirty or defective ID-sensor, or an defective IO-Board.
    • tullio
      • Feb 2012
      • 268
      Re: mp 3500- sc352
      thanks
      • kannuki2
        • Feb 2012
        • 398
        Re: mp 3500- sc352
        Symptom]
        SC 350, SC 352 or SC 390 codes and/or light copies.
        [Cause]
        Toner not being supplied into developer unit.
        [Action]
        Check operation of the Toner Supply Shutter on the bottom of the OPC unit. This shutter has a small tab on it which when pushed against the developer unit pushes the shutter open.
        If the tab/shutter (item 8) is broken replace with; Shutter, toner supply - Part Number G0652241
