probblem with pro 1107EX
  • muthana
    • Nov 2012
    • 23
    hi all
    the problem is whene i copy 50 copy or more the imge will be very light
    i rplace anew toner and i do forced toner supply then the copy is very good then after 50 copy it will be again light
    pleas heip me if ther is any solution for this problem with pro 1107 EX
  • Imprestik
    • Aug 2012
    • 297
    Re: probblem with pro 1107EX
    Have you done a Dev change??
    That would be a start...
    • Vollegaaz
      • 73
      No Sc codes in the background...like sc360 or sc406...?
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        what's your vt and vref, vsp and vsg, and do they change with a forced toner add???
        Mystic Crystal Revelations
        • kannuki2
          • Feb 2012
          • 398
          have you take out your screw driver and open up any parts yet? or you just want us to do the work for you?
