Hi All,
Just wondered if anyone had come across this issue also, I have just refurbished a MPC4500 machine (new pcu/dev, fuser, PTR, cleaning unit) what happens is when you put 120g paper through it smudges the feed edge, doesnt matter if you set it to plain/middle thick/thick 1/thick 2, it always does it, but it doesnt do it on normal 80g stuff. However trying the same thing on a MPC4000 we have here and all is well. This is LEF and only occurs on the feed edge.
The only part not replaced during refurb was the ITB, i tried that in another machine and that didnt produce the fault. All firmware is up to date.
Here is a picture on both 80g and the 120g.
plainpaper.pdf
120paper.pdf
plainpaper.pdf
120paper.pdf
