line on copy when using ARDF
+ More Options
Posts
  • margic brian
    • Jul 2012
    • 97
    [Misc] line on copy when using ARDF
    hello guys,
    this might sound silly but found something that disturbed me when copying from the ardf a line appears what could be the problem and how can i rectify it
    :it an mp4000, cleaned scanner glass rollers in ardf, fitted the paper in the ardf rightly but no changes.
    your help will be appreciated
    thanks
  • Jomama46
    • 2900
    Re: line on copy when using ARDF
    It may be the scanner mirrors, The image centers on a different place for scan and ADF.
    Or it may be a scratch on the ADF scan glass. Replace to check.
    sigpic
    A+; Network +; PDI+
    • Eric1968
      • 2458
      Move the third mirror a little bit upward. Worked for me on an MP C6501.
      • Maluko
        Optics?
        • ruben
          The New Guy
          • Oct 2012
          • 1203
          Is it a long black line down the trailing edge? Check the level of the DF, it could be skewing. Try putting some pressure under the front corner whilst it is scanning to see if it disappears. Either that or alter the edge erase settings.
